ContiGT's avatar
ContiGT
Nighthawk M1 external antenna connectors
Hi folks
I am having problems with my M1 regarding external antenna signal strength - like no improvement! The tech lined the antenna up with the tower on the highest point on my roof but no result!
I have 2 bars signal strength operation in my living room using just the internal antenna but if I take the modem outside and stand inline with the tower location I get 4 bars.
I decided to have an external antenna professionally installed and when the tech connected it up the signal strength remained at 2 bars. I disconnected it and took it outside again to the same position I had 4 bars before and the signal strength jumped back up to 4 bars. The antenna is a Sierra Wireless Technologies Telstra Broadband WMM-8G-7-38-15-TS9.
Is there any way to tell if the antenna ports on the modem are functioning or do they have to be activated within the firmware. Any ideas?
Cheers
Chris
  • The problem isn't on that antenna but the antenna port on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.), unfortunately your environment seems preferred on B7 and that two TS-9 port does not help on B7. There are 4 antennas inside M1, designed for different bands.
  • Quickest way to validate if the external antenna works, take it with you to where you have 4 bars signal, without external antenna, and plug the antenna to see if signal dropped. Theory behind is when you plug external antenna into TS-9 port, the internal antenna will be disconnected.
    You can also check on singal information from SETTINGS->Nighthawk M1 Status->Diagnostic, looking at RSRP, RS-SINR, Quality also Current Radio Band what is changing between with and without external antenna.
    • ContiGT's avatar
      ContiGT
      Many thanks for the reply! I tried as you suggested and signal strength inside was -110db, moved outside to the area I get 4 bars and read off -88db. Plugged the antenna leads in and signal strength did not change! It stayed at -88db ( with +/-2db variation).
      I purchased this unit as a "near new refurbished" item - it appears all is not what it seems!
      • W1lliam's avatar
        W1lliam
        Virtuoso
        Can you check on what is the Current Radio Band? TS-9 port does not support high bands
