Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Pezman
I'm not sure what my next step should be. I keep browsing the forums for more details and in the meantime I downloaded all my logs (via frontview) and spent some time looking over system.log. I'm a total noob and have no idea what I'm looking for, other than I can copy and paste what looks like information right before it "dies" and when I reboot. Here are the two most recent examples:
Here is the second time it happened today:
What is killing the NAS? I can't see a consistant action that does this. What I DO know is that if you look at the logs inside frontview it doesn't even acknowledge that it went offline. It just acknowledges that I manually rebooted the device. I'd love any help you guys can offer.
Jul 15 00:18:51 Readynas kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1
Jul 15 00:18:52 Readynas exportfs[2411]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jul 15 00:18:52 Readynas exportfs[2411]: /proc/fs/nfs/exports:1: unknown keyword "test-client-(rw"
Jul 15 00:18:52 Readynas rpc.statd[2416]: Version 1.1.2 Starting
Jul 15 00:18:52 Readynas sm-notify[2435]: sm-notify running as root. chown /var/lib/nfs/sm to choose different user
Jul 15 00:18:52 Readynas Backgrounding to notify hosts...
Jul 15 00:18:52 Readynas rpc.statd[2416]: statd running as root. chown /var/lib/nfs/sm to choose different user
Jul 15 00:18:52 Readynas kernel: svc: failed to register lockdv1 RPC service (errno 97).
Jul 15 00:18:52 Readynas kernel: NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Jul 15 00:18:52 Readynas kernel: NFSD: starting 90-second grace period
Jul 15 00:18:53 Readynas kernel: warning: `proftpd' uses 32-bit capabilities (legacy support in use)
Jul 15 00:18:54 Readynas kernel: bonding: bond0: setting mode to balance-rr (0).
Jul 15 00:18:54 Readynas kernel: bonding: bond0: Setting MII monitoring interval to 100.
Jul 15 00:18:54 Readynas kernel: ADDRCONF(NETDEV_UP): bond0: link is not ready
Jul 15 00:18:54 Readynas kernel: 8021q: adding VLAN 0 to HW filter on device bond0
Jul 15 00:18:56 Readynas ifplugd(bond0)[2722]: ifplugd 0.28 initializing.
Jul 15 00:18:56 Readynas ifplugd(bond0)[2722]: Using interface bond0/00:00:00:00:00:00 with driver <bonding> (version: 3.7.0)
Jul 15 00:18:56 Readynas ifplugd(bond0)[2722]: Using detection mode: SIOCETHTOOL
Jul 15 00:18:56 Readynas ifplugd(bond0)[2722]: Initialization complete, link beat not detected.
Jul 15 00:18:59 Readynas ifplugd(eth0)[2909]: ifplugd 0.28 initializing.
Jul 15 00:18:59 Readynas ifplugd(eth0)[2909]: Using interface eth0/00:1F:33:EA:62:73 with driver <sk98lin> (version: 10.70.1.3 (01))
Jul 15 00:18:59 Readynas ifplugd(eth0)[2909]: Using detection mode: SIOCETHTOOL
Jul 15 00:18:59 Readynas ifplugd(eth0)[2909]: Initialization complete, link beat detected.
Jul 15 00:19:00 Readynas ifplugd(eth0)[2909]: Executing '/etc/ifplugd/ifplugd.action eth0 up'.
Jul 15 00:19:00 Readynas ifplugd(eth0)[2909]: client: 2917: old priority 0, new priority 0
Jul 15 00:19:00 Readynas ifplugd(eth0)[2909]: client: SIOCADDRT: File exists
Jul 15 00:19:22 Readynas syslogd 1.4.1#18: restart.
Jul 15 00:19:39 Readynas ifplugd(eth0)[2909]: client: Starting plexserver
Jul 15 00:19:45 Readynas ifplugd(eth0)[2909]: Program executed successfully.
Jul 15 00:19:46 Readynas ifplugd(eth1)[3279]: ifplugd 0.28 initializing.
Jul 15 00:19:46 Readynas ifplugd(eth1)[3279]: Using interface eth1/00:1F:33:EA:62:72 with driver <sk98lin> (version: 10.70.1.3 (01))
Jul 15 00:19:46 Readynas ifplugd(eth1)[3279]: Using detection mode: SIOCETHTOOL
Jul 15 00:19:46 Readynas ifplugd(eth1)[3279]: Initialization complete, link beat not detected.
Jul 15 00:20:24 Readynas chronyd[2993]: Invalid host/IP address at line 1
Jul 15 00:20:25 Readynas RAIDiator: System is up.
Jul 15 00:20:31 Readynas kernel: sk98lin 0000:01:00.0: PME# enabled
Jul 15 00:20:31 Readynas kernel: sk98lin 0000:02:00.0: PME# enabled
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Found user 'avahi' (UID 20) and group 'avahi' (GID 20).
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Successfully dropped root privileges.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: avahi-daemon 0.6.23 starting up.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/afp.service.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/cifs.service.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/frontview.service.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/mt-daapd.service.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/readynas.service.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::21f:33ff:feea:6273.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: New relevant interface eth0.IPv6 for mDNS.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.2.120.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: New relevant interface eth0.IPv4 for mDNS.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Network interface enumeration completed.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Registering new address record for fe80::21f:33ff:feea:6273 on eth0.*.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Registering new address record for 192.168.2.120 on eth0.IPv4.
Jul 15 00:20:34 Readynas avahi-daemon[3958]: Registering HINFO record with values 'X86_64'/'LINUX'.
Jul 15 00:20:35 Readynas avahi-daemon[3958]: Server startup complete. Host name is Readynas.local. Local service cookie is 3825488552.
Jul 15 00:20:36 Readynas avahi-daemon[3958]: Service "ReadyNAS Discovery [Readynas]" (/etc/avahi/services/readynas.service) successfully established.
Jul 15 00:20:36 Readynas avahi-daemon[3958]: Service "ReadyNAS Server on Readynas" (/etc/avahi/services/mt-daapd.service) successfully established.
Jul 15 00:20:36 Readynas avahi-daemon[3958]: Service "FrontView on Readynas" (/etc/avahi/services/frontview.service) successfully established.
Jul 15 00:20:36 Readynas avahi-daemon[3958]: Service "Readynas (CIFS)" (/etc/avahi/services/cifs.service) successfully established.
Jul 15 00:20:36 Readynas avahi-daemon[3958]: Service "Readynas (AFP)" (/etc/avahi/services/afp.service) successfully established.
Jul 15 00:21:45 Readynas chronyd[2993]: Invalid host/IP address at line 2
Jul 15 00:24:26 Readynas chronyd[2993]: No usable initstepslew servers at line 3
Jul 15 00:24:26 Readynas chronyd[2993]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Jul 15 00:24:26 Readynas chronyd[2993]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jul 15 00:24:26 Readynas chronyd[2993]: Linux kernel major=2 minor=6 patch=37
Jul 15 00:24:26 Readynas chronyd[2993]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
Jul 15 00:56:06 Readynas kernel: usb 2-3: new high speed USB device using ehci_hcd and address 3
Jul 15 00:56:06 Readynas kernel: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x04B8 pid 0x083C
Jul 15 00:56:06 Readynas kernel: scsi7 : usb-storage 2-3:1.2
Jul 15 00:56:07 Readynas kernel: scsi 7:0:0:0: Direct-Access EPSON Stylus Storage 1.00 PQ: 0 ANSI: 2
Jul 15 00:56:07 Readynas kernel: scsi: killing requests for dead queue
Jul 15 00:56:07 Readynas last message repeated 7 times
Jul 15 00:56:07 Readynas kernel: sd 7:0:0:0: Attached scsi generic sg6 type 0
Jul 15 00:56:07 Readynas kernel: sd 7:0:0:0: [sdg] Attached SCSI removable disk
Jul 15 00:56:09 Readynas avahi-daemon[3958]: Files changed, reloading.
Jul 15 00:56:09 Readynas avahi-daemon[3958]: Loading service file /etc/avahi/services/PRINTER-Stylus_Photo.service.
Jul 15 00:56:09 Readynas avahi-daemon[3958]: Got SIGHUP, reloading.
Jul 15 00:56:10 Readynas avahi-daemon[3958]: Service "EPSON Stylus Photo RX595 on Readynas" (/etc/avahi/services/PRINTER-Stylus_Photo.service) successfully established.
Jul 15 00:56:18 Readynas RAIDiator: USB device sdg has zero size, skipping.
Jul 15 02:21:59 Readynas kernel: plexserver invoked oom-killer: gfp_mask=0x201da, order=0, oom_adj=0, oom_score_adj=0
Jul 15 02:21:59 Readynas kernel: Pid: 3556, comm: plexserver Tainted: P 2.6.37.6.RNx86_64.2.4 #1
Jul 15 02:21:59 Readynas kernel: Call Trace:
Jul 15 02:21:59 Readynas kernel: [<ffffffff8807eeaf>] dump_header+0x6f/0x190
Jul 15 02:21:59 Readynas kernel: [<ffffffff8808ee2a>] ? wait_iff_congested+0xba/0x120
Jul 15 02:21:59 Readynas kernel: [<ffffffff8804d500>] ? autoremove_wake_function+0x0/0x40
Jul 15 02:21:59 Readynas kernel: [<ffffffff8807f3be>] oom_kill_process+0x27e/0x290
Jul 15 02:21:59 Readynas kernel: [<ffffffff8807f61e>] out_of_memory+0x24e/0x300
Jul 15 02:21:59 Readynas kernel: [<ffffffff880825a3>] __alloc_pages_nodemask+0x5f3/0x610
Jul 15 02:21:59 Readynas kernel: [<ffffffff88084c47>] __do_page_cache_readahead+0xe7/0x220
Jul 15 02:21:59 Readynas kernel: [<ffffffff88084d9c>] ra_submit+0x1c/0x20
Jul 15 02:21:59 Readynas kernel: [<ffffffff8807e319>] filemap_fault+0x3b9/0x3c0
Jul 15 02:21:59 Readynas kernel: [<ffffffff88092da0>] __do_fault+0x50/0x490
Jul 15 02:21:59 Readynas kernel: [<ffffffff880bfdb6>] ? dput+0x26/0x130
Jul 15 02:21:59 Readynas kernel: [<ffffffff88094f8c>] handle_mm_fault+0x1ac/0x840
Jul 15 02:21:59 Readynas kernel: [<ffffffff88020139>] do_page_fault+0x139/0x420
Jul 15 02:21:59 Readynas kernel: [<ffffffff880b7bfc>] ? path_put+0x2c/0x40
Jul 15 02:21:59 Readynas kernel: [<ffffffff880b23dc>] ? vfs_fstatat+0x6c/0x70
Jul 15 02:21:59 Readynas kernel: [<ffffffff8805e000>] ? compat_sys_futex+0x90/0x140
Jul 15 02:21:59 Readynas kernel: [<ffffffff8804c1b0>] ? sys_clock_gettime+0x90/0xe0
Jul 15 02:21:59 Readynas kernel: [<ffffffff885b479f>] page_fault+0x1f/0x30
Jul 15 02:21:59 Readynas kernel: Mem-Info:
Jul 15 02:21:59 Readynas kernel: DMA per-cpu:
Jul 15 02:21:59 Readynas kernel: CPU 0: hi: 0, btch: 1 usd: 0
Jul 15 02:21:59 Readynas kernel: CPU 1: hi: 0, btch: 1 usd: 0
Jul 15 02:21:59 Readynas kernel: DMA32 per-cpu:
Jul 15 02:21:59 Readynas kernel: CPU 0: hi: 186, btch: 31 usd: 0
Jul 15 02:21:59 Readynas kernel: CPU 1: hi: 186, btch: 31 usd: 0
Jul 15 02:21:59 Readynas kernel: active_anon:90561 inactive_anon:90683 isolated_anon:0
Jul 15 02:21:59 Readynas kernel: active_file:238 inactive_file:191 isolated_file:32
Jul 15 02:21:59 Readynas kernel: unevictable:381 dirty:0 writeback:0 unstable:0
Jul 15 02:21:59 Readynas kernel: free:5090 slab_reclaimable:5696 slab_unreclaimable:5140
Jul 15 02:21:59 Readynas kernel: mapped:93 shmem:2 pagetables:1795 bounce:0
Jul 15 02:21:59 Readynas kernel: DMA free:4220kB min:248kB low:308kB high:372kB active_anon:5644kB inactive_anon:5880kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15688kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:32kB slab_unreclaimable:0kB kernel_stack:16kB pagetables:88kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
Jul 15 02:21:59 Readynas kernel: lowmem_reserve[]: 0 992 992 992
Jul 15 02:21:59 Readynas kernel: DMA32 free:16140kB min:16132kB low:20164kB high:24196kB active_anon:356600kB inactive_anon:356852kB active_file:952kB inactive_file:764kB unevictable:1524kB isolated(anon):0kB isolated(file):128kB present:1016752kB mlocked:4kB dirty:0kB writeback:0kB mapped:372kB shmem:8kB slab_reclaimable:22752kB slab_unreclaimable:20560kB kernel_stack:1504kB pagetables:7092kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:2942 all_unreclaimable? yes
Jul 15 02:21:59 Readynas kernel: lowmem_reserve[]: 0 0 0 0
Jul 15 02:21:59 Readynas kernel: DMA: 33*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 1*2048kB 0*4096kB = 4220kB
Jul 15 02:21:59 Readynas kernel: DMA32: 1987*4kB 10*8kB 5*16kB 3*32kB 4*64kB 4*128kB 2*256kB 1*512kB 0*1024kB 1*2048kB 1*4096kB = 16140kB
Jul 15 02:21:59 Readynas kernel: 4235 total pagecache pages
Jul 15 02:21:59 Readynas kernel: 3372 pages in swap cache
Jul 15 02:21:59 Readynas kernel: Swap cache stats: add 545169, delete 541797, find 5631/7962
Jul 15 02:21:59 Readynas kernel: Free swap = 0kB
Jul 15 02:21:59 Readynas kernel: Total swap = 2097084kB
Jul 15 02:21:59 Readynas kernel: 261792 pages RAM
Jul 15 02:21:59 Readynas kernel: 6514 pages reserved
Jul 15 02:21:59 Readynas kernel: 1222 pages shared
Jul 15 02:21:59 Readynas kernel: 248631 pages non-shared
Jul 15 02:21:59 Readynas kernel: [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
Jul 15 02:21:59 Readynas kernel: [ 829] 0 829 450 58 1 0 0 ifplugd
Jul 15 02:21:59 Readynas kernel: [ 940] 0 940 611 2 0 -17 -1000 udevd
Jul 15 02:21:59 Readynas kernel: [ 2096] 0 2096 424 0 1 0 0 acpid
Jul 15 02:21:59 Readynas kernel: [ 2102] 0 2102 422 0 0 0 0 raidard
Jul 15 02:21:59 Readynas kernel: [ 2264] 0 2264 633 1 1 0 0 quota_nld
Jul 15 02:21:59 Readynas kernel: [ 2269] 1 2269 453 0 0 0 0 portmap
Jul 15 02:21:59 Readynas kernel: [ 2304] 0 2304 437 9 0 0 0 syslogd
Jul 15 02:21:59 Readynas kernel: [ 2325] 0 2325 489 1 1 0 0 atd
Jul 15 02:21:59 Readynas kernel: [ 2332] 0 2332 425 0 1 0 0 klogd
Jul 15 02:21:59 Readynas kernel: [ 2344] 0 2344 940 7 0 0 0 cupsd
Jul 15 02:21:59 Readynas kernel: [ 2350] 21 2350 688 1 0 0 0 dbus-daemon
Jul 15 02:21:59 Readynas kernel: [ 2353] 0 2353 494 10 0 0 0 cron
Jul 15 02:21:59 Readynas kernel: [ 2397] 0 2397 3722 0 1 0 0 smbd
Jul 15 02:21:59 Readynas kernel: [ 2410] 0 2410 483 0 1 0 0 rpc.rquotad
Jul 15 02:21:59 Readynas kernel: [ 2416] 0 2416 470 0 1 0 0 rpc.statd
Jul 15 02:21:59 Readynas kernel: [ 2418] 0 2418 3722 1 1 0 0 smbd
Jul 15 02:21:59 Readynas kernel: [ 2456] 0 2456 483 1 0 0 0 rpc.mountd
Jul 15 02:21:59 Readynas kernel: [ 2722] 0 2722 431 6 1 0 0 ifplugd
Jul 15 02:21:59 Readynas kernel: [ 2909] 0 2909 431 6 1 0 0 ifplugd
Jul 15 02:21:59 Readynas kernel: [ 2976] 0 2976 11226 23 1 0 0 minidlna
Jul 15 02:21:59 Readynas kernel: [ 2987] 0 2987 534 1 0 0 0 cnid_metad
Jul 15 02:21:59 Readynas kernel: [ 2993] 0 2993 2704 1 0 0 0 chronyd
Jul 15 02:21:59 Readynas kernel: [ 3001] 0 3001 444 0 0 0 0 lld2d
Jul 15 02:21:59 Readynas kernel: [ 3002] 0 3002 424 12 0 0 0 upnpd
Jul 15 02:21:59 Readynas kernel: [ 3007] 0 3007 1779 1 0 0 0 afpd
Jul 15 02:21:59 Readynas kernel: [ 3011] 98 3011 22011 0 1 0 0 mysqld
Jul 15 02:21:59 Readynas kernel: [ 3069] 0 3069 3747 44 1 0 0 smbd
Jul 15 02:21:59 Readynas kernel: [ 3077] 0 3077 3788 69 0 0 0 smbd
Jul 15 02:21:59 Readynas kernel: [ 3079] 0 3079 2829 49 1 0 0 proftpd
Jul 15 02:21:59 Readynas kernel: [ 3085] 0 3085 10517 17 0 0 0 apache-ssl
Jul 15 02:21:59 Readynas kernel: [ 3185] 0 3185 48126 43 1 0 0 plexserver
Jul 15 02:21:59 Readynas kernel: [ 3260] 0 3260 4270 7 1 0 0 mt-daapd
Jul 15 02:21:59 Readynas kernel: [ 3266] 0 3266 454 0 1 0 0 dhcp6c
Jul 15 02:21:59 Readynas kernel: [ 3279] 0 3279 431 6 0 0 0 ifplugd
Jul 15 02:21:59 Readynas kernel: [ 3312] 0 3312 2211 20 0 0 0 nmbd
Jul 15 02:21:59 Readynas kernel: [ 3515] 0 3515 29094 110 1 0 0 Plex DLNA Serve
Jul 15 02:21:59 Readynas kernel: [ 3641] 0 3641 543 29 1 0 0 monitor_enclosu
Jul 15 02:21:59 Readynas kernel: [ 3958] 20 3958 711 39 0 0 0 avahi-daemon
Jul 15 02:21:59 Readynas kernel: [ 3972] 0 3972 425 2 0 0 0 getty
Jul 15 02:21:59 Readynas kernel: [ 5039] 98 5039 11036 1307 0 0 0 apache-ssl
Jul 15 02:21:59 Readynas kernel: [ 5259] 98 5259 13605 314 1 0 0 apache-ssl
Jul 15 02:21:59 Readynas kernel: [ 6679] 0 6679 3782 64 0 0 0 smbd
Jul 15 02:21:59 Readynas kernel: [23521] 0 23521 684512 176035 1 0 0 Plex Media Scan
Jul 15 02:21:59 Readynas kernel: [23653] 98 23653 10517 28 0 0 0 apache-ssl
Jul 15 02:21:59 Readynas kernel: Out of memory: Kill process 23521 (Plex Media Scan) score 832 or sacrifice child
Jul 15 02:21:59 Readynas kernel: Killed process 23521 (Plex Media Scan) total-vm:2738048kB, anon-rss:704140kB, file-rss:0kB
Jul 15 09:36:54 Readynas syslogd 1.4.1#18: restart.
Jul 15 09:36:54 Readynas kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Jul 15 09:36:54 Readynas kernel: Initializing cgroup subsys cpu
Jul 15 09:36:54 Readynas kernel: Linux version 2.6.37.6.RNx86_64.2.4 (jmaggard@calzone) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon May 21 16:00:40 PDT 2012
Jul 15 09:36:54 Readynas kernel: Command line: initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Jul 15 09:36:54 Readynas kernel: BIOS-provided physical RAM map:
Jul 15 09:37:25 Readynas syslogd 1.4.1#18: restart.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Found user 'avahi' (UID 20) and group 'avahi' (GID 20).
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Successfully dropped root privileges.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: avahi-daemon 0.6.23 starting up.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/PRINTER-Stylus_Photo.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/afp.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/cifs.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/frontview.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/mt-daapd.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Loading service file /etc/avahi/services/readynas.service.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::21f:33ff:feea:6273.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: New relevant interface eth0.IPv6 for mDNS.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.2.120.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: New relevant interface eth0.IPv4 for mDNS.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Network interface enumeration completed.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Registering new address record for fe80::21f:33ff:feea:6273 on eth0.*.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Registering new address record for 192.168.2.120 on eth0.IPv4.
Jul 15 09:38:11 Readynas avahi-daemon[3897]: Registering HINFO record with values 'X86_64'/'LINUX'.
Jul 15 09:38:12 Readynas avahi-daemon[3897]: Server startup complete. Host name is Readynas.local. Local service cookie is 780553564.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "ReadyNAS Discovery [Readynas]" (/etc/avahi/services/readynas.service) successfully established.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "ReadyNAS Server on Readynas" (/etc/avahi/services/mt-daapd.service) successfully established.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "FrontView on Readynas" (/etc/avahi/services/frontview.service) successfully established.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "Readynas (CIFS)" (/etc/avahi/services/cifs.service) successfully established.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "Readynas (AFP)" (/etc/avahi/services/afp.service) successfully established.
Jul 15 09:38:13 Readynas avahi-daemon[3897]: Service "EPSON Stylus Photo RX595 on Readynas" (/etc/avahi/services/PRINTER-Stylus_Photo.service) successfully established.
Jul 15 09:38:27 Readynas chronyd[3040]: Invalid host/IP address at line 1
Jul 15 09:39:48 Readynas chronyd[3040]: Invalid host/IP address at line 2
Jul 15 09:42:29 Readynas chronyd[3040]: No usable initstepslew servers at line 3
Jul 15 09:42:29 Readynas chronyd[3040]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Jul 15 09:42:29 Readynas chronyd[3040]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jul 15 09:42:29 Readynas chronyd[3040]: Linux kernel major=2 minor=6 patch=37
Jul 15 09:42:29 Readynas chronyd[3040]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
Jul 15 12:18:04 Readynas syslogd 1.4.1#18: restart.
Jul 15 12:18:05 Readynas kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Jul 15 12:18:05 Readynas kernel: Initializing cgroup subsys cpu
Jul 15 12:18:05 Readynas kernel: Linux version 2.6.37.6.RNx86_64.2.4 (jmaggard@calzone) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon May 21 16:00:40 PDT 2012
Jul 15 12:18:05 Readynas kernel: Command line: initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Jul 15 12:18:05 Readynas kernel: BIOS-provided physical RAM map:
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 0000000000000000 - 000000000009cc00 (usable)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 000000000009cc00 - 00000000000a0000 (reserved)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 0000000000100000 - 000000003feb0000 (usable)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 000000003feb0000 - 000000003febe000 (ACPI data)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 000000003febe000 - 000000003fef0000 (ACPI NVS)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 000000003fef0000 - 000000003ff00000 (reserved)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Jul 15 12:18:05 Readynas kernel: BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
Jul 15 12:18:05 Readynas kernel: NX (Execute Disable) protection: active
