Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Bigbearf
It appears that your Load Cycle Counts are high. Did you run the WDIDLE /D and TLER ON on your WD Drives. I think the one with over a million LCCs may be a problem. See my prior posts for tips on running the WDIDLE and TLER dos programs on your WD green drives to halt LLC escalations. I have started replacing my WD20EADS drives with WD2003FYYS enterprise drives and they work great. They are about $225 on Amazon Prime.
Hope this helps.
bigbearf
Hope this helps.
bigbearf
