Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Pezman
Sep 18, 2013Aspirant
Update: I have now replaced the power supply and used an ATX extender to make it reach. However, the original problem of random reboots persists!
Can someone please what next steps I should look into?
To restate the the issue for anyone needing a TLDR summary:
My Readynas Pioneer Pro randomly reboots for no logical reason. It does this several times a day. I have contacted support who ultimately told me that it was a bad power supply, which I have now replaced and still have the same issue. I was also told it was Plex, so I have uninstalled plex and do not use it any longer. I have since had to purchase another Pro 6 to copy all this data over to it so I don't lose work and then I performed a factory reset (I believe, is there a way to check?) and now started moving files back over to it. Once again, it started rebooting for no reason!!
When it comes back online it always says "Resync C:" sometimes the Resync doesn't finish before the next random reboot
Ack! I could kick this thing.
I am using RAIDiator 4.2.22 which was the latest available back in March. I could update, but I doubt that fixes much.
Thus far I have pushed a significant amount of money into resolving this and the original issue still occurs.
This is what my frontview log view shows:
Download All Logs
Severity Date Message
Wed Sep 18 23:42:03 PDT 2013 System is up.
Wed Sep 18 23:10:01 PDT 2013 System is up.
Wed Sep 18 20:42:42 PDT 2013 System is up.
Wed Sep 18 19:20:18 PDT 2013 System is up.
Wed Sep 18 17:57:43 PDT 2013 System is up.
Wed Sep 18 17:51:11 PDT 2013 System is up.
Wed Sep 18 15:17:56 PDT 2013 System is up.
Wed Sep 18 14:11:27 PDT 2013 System is up.
Wed Sep 18 13:55:51 PDT 2013 System is up.
Wed Sep 18 13:36:44 PDT 2013 System is up.
Wed Sep 18 13:05:54 PDT 2013 System is up.
Wed Sep 18 12:02:23 PDT 2013 System is up.
Wed Sep 18 11:28:08 PDT 2013 System is up.
Wed Sep 18 11:09:35 PDT 2013 System is up.
Wed Sep 18 10:35:32 PDT 2013 System is up.
Wed Sep 18 07:51:52 PDT 2013 System is up.
Wed Sep 18 04:21:06 PDT 2013 System is up.
Tue Sep 17 21:19:42 PDT 2013 The ReadyNAS Replicate add-on encountered an error during installation.
Tue Sep 17 21:19:41 PDT 2013 The ReadyNAS Replicate add-on has been successfully installed.
Tue Sep 17 21:13:39 PDT 2013 Successfully started NFS service.
Tue Sep 17 21:07:20 PDT 2013 [Work] added with default access. Please review the share access restrictions in the Share Listing page to fine-tune any default settings.
Tue Sep 17 21:07:20 PDT 2013 [Files] added with default access. Please review the share access restrictions in the Share Listing page to fine-tune any default settings.
Tue Sep 17 21:07:20 PDT 2013 [Apps] added with default access. Please review the share access restrictions in the Share Listing page to fine-tune any default settings.
Tue Sep 17 21:05:35 PDT 2013 [backup] The share and its subfolders have been configured to allow non-owner delete and rename.
Tue Sep 17 20:57:37 PDT 2013 System is up.
Sat Apr 6 07:03:00 PDT 2013 System is up.
Sat Apr 6 05:00:05 PDT 2013 RAID scrubbing started on volume C.
Tue Apr 2 19:30:09 PDT 2013 System is up.
Thu Mar 21 22:22:33 PDT 2013 System is up.
Thu Mar 21 08:45:28 PDT 2013 RAID sync finished on volume C.
Thu Mar 21 04:45:02 PDT 2013 System is up.
Thu Mar 21 02:34:01 PDT 2013 System is up.
Thu Mar 21 01:52:25 PDT 2013 System is up.
Thu Mar 21 01:10:55 PDT 2013 System is up.
Wed Mar 20 23:24:35 PDT 2013 System is up.
Wed Mar 20 23:00:11 PDT 2013 RAID scrubbing started on volume C.
Wed Mar 20 02:03:49 PDT 2013 RAID sync finished on volume C.
Tue Mar 19 21:42:24 PDT 2013 System is up.
Tue Mar 19 21:42:19 PDT 2013 Data volume has been successfully expanded to 8317 GB.
Tue Mar 19 21:42:10 PDT 2013 Continuing with volume expansion or migration. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list.
Tue Mar 19 21:39:20 PDT 2013 Rebooting device...
Tue Mar 19 21:39:20 PDT 2013 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Tue Mar 19 14:20:44 PDT 2013 Found space that can be used to expand capacity, expansion process will start during next boot.
Tue Mar 19 14:20:43 PDT 2013 RAID sync finished on volume C.
Tue Mar 19 10:16:07 PDT 2013 System is up.
Tue Mar 19 10:16:06 PDT 2013 Found space that can be used to expand capacity, expansion process will start during next boot.
Tue Mar 19 10:16:03 PDT 2013 Data volume has been successfully expanded to 7389 GB.
Tue Mar 19 10:15:46 PDT 2013 Continuing with volume expansion or migration. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list.
Tue Mar 19 10:14:50 PDT 2013 System is up.
Tue Mar 19 10:13:45 PDT 2013 Rebooting device...
Tue Mar 19 10:13:45 PDT 2013 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Tue Mar 19 10:13:04 PDT 2013 Successfully set new hostname.
Tue Mar 19 01:24:32 PDT 2013 Found space that can be used to expand capacity, expansion process will start during next boot.
Tue Mar 19 01:24:31 PDT 2013 RAID sync finished on volume C.
Tue Mar 19 00:36:26 PDT 2013 System is up.
Mon Mar 18 23:47:47 PDT 2013 System is up.
Mon Mar 18 22:24:04 PDT 2013 System is up.
Mon Mar 18 21:02:13 PDT 2013 System is up.
Mon Mar 18 20:18:45 PDT 2013 System is up.
