Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Sep 19, 2013Guru - Experienced User
If you lost your data after you reset, then you did one.
I'd contact support again, and tell them them power supply didn't fix it. They should RMA the entire unit.
