Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Sep 20, 2013Guru - Experienced User
You are suggesting that he remove the existing disks (powered down) and insert scratch disks to see? The alternative would be to factory reset with one or two disks installed, and recover everything from backup later on.
mdgm wrote: If you just have one or two disks in the NAS do you still have this issue?
One possibility is that the replacement supply doesn't have quite enough power. I think that might be where mdgm is going. What supply did you purchase?
Are you using the same drives you had back in July 2012? Also, I am wondering if disk spindown is still disabled?
