Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Pezman
Sep 20, 2013Aspirant
Additional Information:
Under my desk I have two ReadyNases. One is a Pro 6 with 6x3TB WD Red Drives. The other (the one that doesn't work as well) is plugged into a different socket and is a Pioneer Pro 6 with 2xWD20EARX, 2xWD10EADS (Green), and 2xWD30FFRX. The Pro 6 never has had a reboot issue. This is my second Pioneer Pro 6 (The first one in this same config also did not have this reboot issue)
At your recommendation, I have removed the 2xWD10EADS (Green), and 2xWD30FFRX and rebooted the device. I'll let it run for a bit with only the 2 EARX in and see if the random rebooting it persists.
