Pezman
Jul 15, 2012Aspirant
Pioneer Pro stops responding (4.2.21) #18988091
Hello, I seem to be suffering from a problem that I don't see others mentioning when using 4.2.21. I own a recently RMAed Pioneer Pro 6 bay Readynas. My old Pioneer would lock up several times a...
Pezman
Sep 21, 2013Aspirant
After three hours, the machine has not yet rebooted with only two hard drives. By now under normal conditions it would have rebooted about 2 times.
I'm am going to add two more drives back and see if the rebooting returns under the load of 4 drives.
As for the question of "What Power Supply" I purchased this: SeaSonic SS-300SFD 300W SFX12V v3.1 80 PLUS Certified Active PFC Power Supply - OEM
http://www.newegg.com/Product/Product.a ... 300W%20%25
Do you have a recommendation of a better unit to purchase? I'll gladly do so, this just happened to be what was originally in the box (as best as I could tell from the model numbers
