Chrisis
Oct 30, 2015Tutor
Plex-like mediaserver for ReadyNAS Duo V1
Hello, I have a ReadyNAS Duo V1 and would link to watch movies on my Chromecast. Normally Plex would do the job, but as far as I know Plex is not compattible with the Duo V1 So what are my ...
- Oct 31, 2015
You could install a DLNA client on the Chromecast and run ReadyDLNA on the ReadyNAS but do note that the Chromecast will only be able to play files that it can be streamed to it as is, as your ReadyNAS cannot transcode. If the media is in the wrong format or too high quality the Chromecast won't be able to play it.
mdgm-ntgr
Oct 30, 2015NETGEAR Employee Retired
You can use the NAS as storage for Plex Media Server, but if you want a NAS to run e.g. Plex I would look at getting the RN212/RN214 or the RN516.
The Duo v1 can only stream video as is, so if you want to use it to store the video you could use a PC to run the server and transcode the video for streaming to a client device.
Chrisis
Oct 31, 2015Tutor
Thanx for yous quick answer!
But what about the dlna?
How does that work?
- mdgm-ntgrOct 31, 2015NETGEAR Employee Retired
