DADsNAS
Oct 24, 2016Tutor
PLEX Won't run/load on RN316 after upgrade to 6.6.0
Prior to updating to 6.6.0, PLEX was running fine. After the updae, PLEX was removed from my system (w/o my intervention). Since the upgrade, I have been unable to any verstion of PLEX manually (in...
- Oct 25, 2016
I manually installed Plex from the backend and updated OwnCloud.
Glad that Plex is now working again for you.
Oct 24, 2016Guru - Experienced User
Did you try rebooting the system, and try uploading plex again (via the apps page).
There were some missing packages in the NAS, and Netgear pushed an update (which should happen automatically when you reboot).
Note that info from Netgear suggests that the problem was limited to the arm platforms, so the reboot/retry might not work (but will do no harm).
DADsNAS
Oct 24, 2016Tutor
Thank you for the reply.
Yes, I have rebooted several times. Just to make sure something hadn't been added recently, I just rebooted with the same result ("Cannot Install Application").
