DADsNAS
Oct 24, 2016Tutor
PLEX Won't run/load on RN316 after upgrade to 6.6.0
Prior to updating to 6.6.0, PLEX was running fine. After the updae, PLEX was removed from my system (w/o my intervention). Since the upgrade, I have been unable to any verstion of PLEX manually (in...
- Oct 25, 2016
I manually installed Plex from the backend and updated OwnCloud.
Glad that Plex is now working again for you.
mdgm-ntgr
Oct 24, 2016NETGEAR Employee Retired
Any other apps installed?
Plex on the RN316 should have just worked after the upgrade.
DADsNAS
Oct 24, 2016Tutor
mdgm, thanks for the response.
The other two apps installed are 'Owncloud' & 'SMB Plus'. PLEX Server (0.9.146) was installed and running before the upgrade to 6.6.0. After the upgrade to 6.6.0, the PLEX app was removed from my system, without my initiation, It just dissappeared from the system.
Since then I have not been able to re-install any of the last three versions.
- mdgm-ntgrOct 25, 2016NETGEAR Employee Retired
