pauldurdin
Mar 02, 2019Aspirant
Power failure
This morning the device is not working at all - no lights, nothing. The power adaptor is proving 12V, but there is no activity on the NAS.
I'm looking for advice about what to do next. Is there any...
pauldurdin
Thanks for the reply. I have taken the drives out and nothing. No lights, no fan, nada. So RAIDar doesnt get started! It feels like a power supply failure so i'm tempted to buy a new adaptor - must be worth a try @ £13. The pins have 12V on them, but that doesnt mean that it is supplying enough when loaded.
The other thing a thought of was that i should check that the fan works. It wouldn't be the first computer that wont start because of an interlock.
You are right about a backup solution. This has been a long running topic. I used to use tapes but they were unrelaible. These days i want off site storage, e.g. cload storage. The two possibilities that i tried previously didnt seem to work reliably. My latest thought was to sync with another device located somewhere else - but havent got round to it yet.
Sandshark
Mar 04, 2019Sensei
I don't have a 104, but I am not aware of any ReadyNAS that will fail to start because of a non-fuctioning fan. The power supply does sound like a possibility. Can you measure the input voltage (with the load connected)?
- pauldurdinMar 05, 2019Aspirant
some (long) time ago i had a pc that failed to start because it was monitoring the fans feedback signal to check that they were operating, and one of the fans had died. I wondered if the NAS was doing the same (otherwise what is the point of the feedback signal wire).
I checked the power supply on it's own and i see 12v.
I checked the fan with a separate 12v supply and it works fine, and substituted with another that had monitoring points.
Without the fan connected i see 12v on the pins on the NAS circuit board, but when i plug in (either fan) the voltage drops to nearly zero. So i'm buying a replacement power supply. I'm assuming that there is a high impedance in the power supply - either a damaged cable or dry joint somewhere.
- SandsharkMar 05, 2019Sensei
Hopefully, it's just the supply. The other possibility is that something in the NAS is shorting out the 12V (maybe a bad capacitor). Did you also measure resistance into the NAS to see it's not a dead short?
I once bought a used, non-working NAS being "sure" I could fix it with a power supply swap. No such luck, it was something shorted on the motherboard. But the rest of the parts were worth what I paid.
- pauldurdinMar 06, 2019Aspirant
Thanks for the response. The replacement power pack turned up today, but didn't fix the problem. Gonna have to get more technical with the motherboard i think.
What did you mean by measureing the resitance into the NAS? I cant access the internals of the power pack.
