vrspectre
Jan 04, 2017Apprentice
Power off after disk failure
So I had a drive email me as failed during my most recent test. It was still using the drive though. So i pulled out the old drive, and swapped in the new one. Of course when I pulled out the old one...
- Jan 06, 2017
Hello vrspectre,
Did you have any power schedule set?
Please send system logs and include the link to this topic.
JennC
Jan 05, 2017NETGEAR Employee Retired
Hello vrspectre,
We need more details.
- What is the model of the NAS?
- How many disks are inserted?
- Which drive did you replace?
- What's the current firmware version?
- What's the RAID level?
- When you removed the disk, did you try accessing the shares?
- vrspectreJan 05, 2017Apprentice
I have the readynas 516.
all 6 drive bays had 4TB WD Red drives.
bay 2 is the one that i replaced.
i replaced it with a 6TB WD Red drive
firmware 6.? (i don't remember) it's a home, but, it's whatever is the latest one in production, no beta.
raid is xraid. i believe it to be raid 6
no, after i removed the disk, the first thing i did was replace it.
then after i put the drive in, i did access the shares.
- JennCJan 06, 2017NETGEAR Employee Retired
Hello vrspectre,
- vrspectreMar 05, 2017Apprentice
Sorry. Got swamped and forgot to followup on this. yes I have it set to power down on disk failure. so that's the culprit right there. although maybe it should be smart enough to see a disk was replaced is not a disk failure. but who knows. i'm good with this. thanks.
- JennCJan 09, 2017NETGEAR Employee Retired
Hello vrspectre,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
