jimcocteau
Dec 02, 2017Guide
Power Outage - Resyncing ReadyNAS 104
Hi, I just had two power outages and now my NAS 104 is resyncing should I leave or restart? And yes I need to get a UPS! Firmware 6.9.0 4 4TB Drives 50% full. The resync will takes days fro what ...
- Dec 03, 2017
Thanks a_carneiro,
Robooted and its commenced recync cycle so heres hoping all will be okay. I will setup the UPS and connect my other NAS ASAP.
I do expect a couple of days at least to finish, I am presuming all my data will be okay.
Jim
a_carneiro
Dec 03, 2017Tutor
Just leave it to do its thing.
The 104 is a very underpowered model so the resync will be a long, slow process which should take around 5 days for that capacity (if memory serves right).
- jimcocteauDec 03, 2017Guide
Thanks,
We just had a second power failure, its back up now, I did pull the pwer plug out so if there was a power surge with the power reconnection it would not do more damage.
Would it be sefe to re-boot now?
I do have a second Reday NAS4 that is fine.
I have also ordered a UPS.
- a_carneiroDec 03, 2017Tutor
Well, should be safe to reboot assuming you're not expecting another power failure
The UPS is the obvious choice, all of my ReadyNAS boxes are UPSed :)
Thanks a_carneiro,
Jim
