jimcocteau
Dec 02, 2017Guide
Power Outage - Resyncing ReadyNAS 104
Hi, I just had two power outages and now my NAS 104 is resyncing should I leave or restart? And yes I need to get a UPS! Firmware 6.9.0 4 4TB Drives 50% full. The resync will takes days fro what ...
- Dec 03, 2017
Thanks a_carneiro,
Robooted and its commenced recync cycle so heres hoping all will be okay. I will setup the UPS and connect my other NAS ASAP.
I do expect a couple of days at least to finish, I am presuming all my data will be okay.
Jim
jimcocteau
Dec 03, 2017Guide
Thanks,
We just had a second power failure, its back up now, I did pull the pwer plug out so if there was a power surge with the power reconnection it would not do more damage.
Would it be sefe to re-boot now?
I do have a second Reday NAS4 that is fine.
I have also ordered a UPS.
a_carneiro
Dec 03, 2017Tutor
Well, should be safe to reboot assuming you're not expecting another power failure
The UPS is the obvious choice, all of my ReadyNAS boxes are UPSed :)
- jimcocteauDec 03, 2017Guide
Thanks a_carneiro,
Jim
- a_carneiroDec 03, 2017Tutor
Unless there has been any damage to teh HDDs from the power outages, I would expect your data to be absolutely fine, yes.
In fact, you should be able to access it whilst it unit is resyncing. Performance will be significantly impacted, though
Good luck! :D
Andre
Thanks again,
Yes, I can access all data so its looking okay at the monent , 11% completed!
:smileyhappy:
Jim
- Marc_VDec 03, 2017NETGEAR Employee Retired
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.Regards
