jimcocteau
Dec 02, 2017Guide
Power Outage - Resyncing ReadyNAS 104
Hi, I just had two power outages and now my NAS 104 is resyncing should I leave or restart? And yes I need to get a UPS! Firmware 6.9.0 4 4TB Drives 50% full. The resync will takes days fro what ...
- Dec 03, 2017
Thanks a_carneiro,
Robooted and its commenced recync cycle so heres hoping all will be okay. I will setup the UPS and connect my other NAS ASAP.
I do expect a couple of days at least to finish, I am presuming all my data will be okay.
Jim
a_carneiro
Dec 03, 2017Tutor
Well, should be safe to reboot assuming you're not expecting another power failure
The UPS is the obvious choice, all of my ReadyNAS boxes are UPSed :)
jimcocteau
Dec 03, 2017Guide
Thanks a_carneiro,
Jim
- a_carneiroDec 03, 2017Tutor
Unless there has been any damage to teh HDDs from the power outages, I would expect your data to be absolutely fine, yes.
In fact, you should be able to access it whilst it unit is resyncing. Performance will be significantly impacted, though
Good luck! :D
Andre
- jimcocteauDec 03, 2017Guide
Thanks again,
Yes, I can access all data so its looking okay at the monent , 11% completed!
:smileyhappy:
Jim
