jfrappier
Dec 28, 2012Aspirant
Powershift customer needs L3 support to fix reboot loop
I called into the support number, they had me do an OS reinstall, issue persisted. Booted into tech support mode but the IP address does not work on our network. Have my laptop plugged into the 2nd ...
beisser1
Jan 02, 2013Tutor
has there been a case opened with support? if yes, can you give me the casenumber?
- Nov 30, 2019Retired_Member
