Bains
Nov 08, 2013Guide
Premissions and CryptoLocker
ReadyNAS 312 systems deployed in various locations. Most workstations are accessing NAS hosted data via mapped drives in a peer networking environment. Everyone around here is clucking about Cry...
Nov 11, 2013Guru - Experienced User
http://www.genie9.com/home/Genie_Backup ... rview.aspx claims it can back up externally using FTP/FTPS as the protocol. The suggestion was to use that.
Using UNC for the backup folder (instead of a mapped drive) would also work.
Frontview backup can reach Windows shared folders, and back them up. But there are several operational challenges if you attempt to set up a backup schedule using that mechanism - particularly if the user PCs are not available or turned off when the backup is attempted. It also just does file copy, there is no versioning, etc.
