kcallis
May 15, 2012Aspirant
Printing issues
I have been banging my head against the wall in trying to get printing working. This has only been tested under Ubuntu 12.04, as I have not had access to a Windows machine. I attempted to add a LJ Des...
kcallis
May 23, 2012Aspirant
Thanks, that was the solution... I had been using the network found connection, and that continued to fail. Also, another problem is that the printer name was some funky name (As opposed to a simple dj_4260 or something like that). When I used a simple smb connection, and added a username and password (in the case, admin, although I would rather add users to cupsd.conf and be able to specify use), I finally received my first test print. Thanks you for your pointers!
