giosheringam
Jun 09, 2017Aspirant
Private Time Machine not working on ReadyNas 102 - Sierra and Firmware 6.7.4
Hello, I have moved to a new home and changed the router. Everything worked fine since I have brought here my ReadyNas 102, connected via Ethernet to the router, and tried to backup my Mac again, a...
Jun 09, 2017Guru - Experienced User
If you specify afp:// in finder does that work?
- giosheringamJun 09, 2017Aspirant
No, in fact I discovered it connected via SMB.
I have kept only afp on as a service and didn't manage to connect, also via finder.
- StephenBJun 09, 2017Guru - Experienced User
I don't own a Mac, but my understanding is that Time Machine needs AFP to be on. If the OSX system can't reach the NAS via AFP, I think you need to fix that first.
It might also help to turn on UPNP in the ReadyNAS.
Yes, I guess there is something wrong with AFP. The strange thing is that before it worked fine.
And I know that Apple is leaving AFP, which is ok, as long as it moves TimeMachine also on SMB...
I will try with a Lacie Nas. If it works, then it's not 100% Apple faults.
