giosheringam
Jun 09, 2017Aspirant
Private Time Machine not working on ReadyNas 102 - Sierra and Firmware 6.7.4
Hello, I have moved to a new home and changed the router. Everything worked fine since I have brought here my ReadyNas 102, connected via Ethernet to the router, and tried to backup my Mac again, a...
Jun 09, 2017Guru - Experienced User
If you specify afp:// in finder does that work?
giosheringam
No, in fact I discovered it connected via SMB.
I have kept only afp on as a service and didn't manage to connect, also via finder.
- StephenBJun 09, 2017Guru - Experienced User
I don't own a Mac, but my understanding is that Time Machine needs AFP to be on. If the OSX system can't reach the NAS via AFP, I think you need to fix that first.
It might also help to turn on UPNP in the ReadyNAS.
- giosheringamJun 09, 2017Aspirant
Yes, I guess there is something wrong with AFP. The strange thing is that before it worked fine.
And I know that Apple is leaving AFP, which is ok, as long as it moves TimeMachine also on SMB...
I will try with a Lacie Nas. If it works, then it's not 100% Apple faults.
- giosheringamJun 10, 2017Aspirant
Today's update. After many tries and guessing, I have come until now to the conclusion that the problem is the D-Link router. When I reboot the router, the AFP connection to the NAS appears in Finder for a glimpse, and then no more. So for cross-check I have connected directly the ReadyNas to the Mac via Ethernet with both static IPs. It connected perfectly and now it started the backup.
I have mailed to the D-Link to know something more, and if I can fix the problem.
So many mobile parts in these problems!
I'll keep you updated...
Thanks for guiding me to the maybe possible solution.
