Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
sphardy1
Jul 04, 2011Apprentice
To get a baseline performance - first try testing when directly connected. That way if you have performance issues you immediately rule out network effects and narrow the cause down to your NAS, PC or ethernet cable. Also, don't then just assume the NAS is at fault if you still have an issue - it may be, but there are also many such reports on this forum where updated network drivers for instance have had a major impact on performance
