Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
beisser1
Jul 07, 2011Tutor
temp1 is the chipset temnperature and 58°C is quite ok. temp2 is the cpu and also ok. drives at 39 are also ok.
do i understand this right? you only benchmark with 1 drive? i never tried only 1 drive, but that could be the reason.
with 3 or more disks (normal setup) you will get proper speeds.
do you have jumbo frames enabled? if so try disabling them.
