Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
mdgm-ntgr
Jul 16, 2011NETGEAR Employee Retired
What disk(s) are in your PC? Are you using RAID in it? If you have a single mechanical hard disk in your PC that would probably be the bottleneck.
