Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
victorhortalive
Jul 17, 2011Aspirant
When I had this sort of problem before it turned out to be outdated NIC drivers.
I was running Win7 32bit using an Intel PRO/1000 PT PCIe.
Even after updating the drivers I found Read speed to be lower than Write speed.
I did manage to get 90MBps Write and 80+MBps Read.
This was to/from a ProPioneer with 5 drives using 9K Jumbo Frames through 2
Netgear GS108tV1 switches and CAT6 LAN.
