Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
victorhortalive
Jul 17, 2011Aspirant
FYI my PC was an i3-540 on a Gigabyte M-ITX mobo using an Intel SSD.
I had much the same I/O results using the mobo NIC - Realtek RTL8111E.
Have you tried changing the Flow Control settings ? I changed them to be active.
I also remember that there were problems with the settings on the switches.
You might also install NetMeter on the PC and have a look at the trace of the data transfers. I found that there was a lot of up/down traffic that caused stop/start behaviour.
It's here : http://www.metal-machine.de/readerror/i ... ;dl=item23
