Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
Jul 18, 2011Guru - Experienced User
Oops, sorry I misread it. The T410 is a laptop, it has a single 500 GB hard drive (7200 rpm, but only 60 MB/s). So I can only get useful numbers for it with IOmeter, since if I copy information to the drive, I will be limited by it. I have some esata drives that are faster, but haven't had a chance to plug them in. The Vista machine does not have raid. The C drive is a performance WD 1 TB (forget the exact model), there is also a 2 TB WD and a 1 TB Seagate. All run in excess of 100 MB/s. I also have an XP desktop with 3-4 fast drives, but haven't tried that one for benchmarking. (Also doesn't run raid).
mdgm wrote: When I said PC, I was referring to your Windows machine not the NAS.
How many and what disks are in your Windows machine? Are you using RAID in your Windows machine?
thx for the pointer on Netmeter. Flow control is on in the NIC cards (and also is enabled in the GS108Tv2). The Vista machine has RealTek RTL8168C(P)/8111C(P), the T410 has an Intel 82577LM. IF anyone has suggesting settings for either, that would be useful.
victorhortaliveson wrote: FYI my PC was an i3-540 on a Gigabyte M-ITX mobo using an Intel SSD.
I had much the same I/O results using the mobo NIC - Realtek RTL8111E.
Have you tried changing the Flow Control settings ? I changed them to be active.
I also remember that there were problems with the settings on the switches.
You might also install NetMeter on the PC and have a look at the trace of the data transfers. I found that there was a lot of up/down traffic that caused stop/start behaviour.
It's here : http://www.metal-machine.de/readerror/i ... ;dl=item23
BTW, I get much faster IOmeter readings if I change the number of outstanding transactions from 1 to something higher. So there may be a clue there.
