Jul 04, 2011Guru - Experienced User
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulte...
victorhortalive
Jul 18, 2011Aspirant
StephenB wrote:
BTW, I get much faster IOmeter readings if I change the number of outstanding transactions from 1 to something higher. So there may be a clue there.
I had the same sort of problem.
I was using ViceVersa to mirror between two ProPioneers through the PC. If I started two instances then the overall transfer rate increased dramatically. It was as if something was timing out with one instance but wasn't with more than one.
I forget how I solved this, but I reinstalled practically everything inc the OS on the 2 NASs.
Having a misbehaving drive also makes Read rates drop off.
