tony359
May 23, 2014Apprentice
Pro 6 reading performance
Hi there, I'd like your opinion on a performance questions I have. The NAS is a Pro 6 with two WDC RED 4TB. If I send a big 30GB file to the NAS, I can see it goes through without slowing dow...
tony359
May 24, 2014Apprentice
Sorry I forgot to post the SMART details. I have already checked that the drives were not parking the heads too often, the value is set to 300s
I'll try to check windows errors on my NIC. Haven't found an easy way to do it yet!
I'm sure it was not happening before. The difference may be the new drives. I can try and stick in an old one and see if that happens anyway. I have also upgraded my NIC's driver, I'll test again later.
Thanks for your help!
Edit:
Ok, also found the way to read statistics under windows. it's
netstat -es (to reset statistics, disable and enable your NIC).
Here you go. During the transfer I monitored the NAS statistics. There was already a dropped package, and it stayed there. I believe dropped packages are not bad per se. Those are not errors, are just packages which did not apply/belong to that NIC. I also read somewhere that some Linux kernels/drivers (not a massive expert here) had a bug which was resulting in several dropped packages.
NAS statistics after a large transfer
Windows statistics
Windows is indeed showing lots of discarded packages, but I have no idea what that does mean.
Edit:
eth0 Link encap:Ethernet HWaddr xxxxxxxxxxxxxx
inet addr:xxxxxxxxxxxxxx Bcast:xxxxxxxxxxxx Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10095143 errors:0 dropped:1 overruns:0 frame:0
TX packets:18984628 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:693585858 (661.4 MiB) TX bytes:28151763483 (26.2 GiB)
Interrupt:16 Memory:ff6fc000-0
Windows statistics
netstat -es -p IP
Interface Statistics
Received Sent
Bytes 657126268 2393232782
Unicast packets 75965830 40350488
Non-unicast packets 1048 20072
Discards 0 0
Errors 0 0
Unknown protocols 0
IPv4 Statistics
Packets Received = 19066880
Received Header Errors = 0
Received Address Errors = 0
Datagrams Forwarded = 0
Unknown Protocols Received = 0
Received Packets Discarded = 1756
Received Packets Delivered = 19070390
Output Requests = 10149103
Routing Discards = 1
Discarded Output Packets = 7111
Output Packet No Route = 68
Reassembly Required = 0
Reassembly Successful = 0
Reassembly Failures = 0
Datagrams Successfully Fragmented = 0
Datagrams Failing Fragmentation = 0
Fragments Created = 0
