apoleon
May 30, 2014Aspirant
Pro Pioneer fan failed (?)
Hello! I have a ReadyNAS Pro Pioneer Edition 6-bay NAS device, about 4.5 years old. Running constantly without any major probems (once, however, I had to move all data off and reformat the system d...
apoleon
Ok, did some more searching and found out a couple threads. Granted, none of them have the same problem I have, but there are several threads describing how to replace the fans, particularly
http://www.readynas.com/forum/viewtopic.php?f=24&t=39652
I still do have a couple of questions:
The documentation talks about a third fan, Disk exhaust fan. But nobody has talked about replacing it. Is is a new addition, or has it been removed, or something else?
The documentation talkes about the following specs:
– Software-controlled 120 mm chassis cooling fan
– 90 mm CPU cooling fan
But other users talk about NF-R8 as a CPU fan replacement. But that is a 80mm fan. Getting confused here. I guess I have to open the case and measure the fan?
