apoleon
May 30, 2014Aspirant
Pro Pioneer fan failed (?)
Hello! I have a ReadyNAS Pro Pioneer Edition 6-bay NAS device, about 4.5 years old. Running constantly without any major probems (once, however, I had to move all data off and reformat the system d...
apoleon
May 31, 2014Aspirant
If you haven't purchased those fans yet, better choices might be the NF-S12A FLX and the NF-R8 PWM.
Thanks for the tip. I was actually thinkinf og the NF-S12A FLX, but wasn't sure if it would work so I decided to take the safe route. But I changed my order as you recommended. I should have two new fans by the end of next week, after which I will have more fans than Justin Bieber.
The Patriot PSD28G800K (2 x 4GB) will work well in the Pro Pioneer.
Holy cow those are expensive. I'll settle for 2X2Gb for now :)
Thanks everybody for the tips!
