apoleon
May 30, 2014Aspirant
Pro Pioneer fan failed (?)
Hello! I have a ReadyNAS Pro Pioneer Edition 6-bay NAS device, about 4.5 years old. Running constantly without any major probems (once, however, I had to move all data off and reformat the system d...
apoleon
Jun 05, 2014Aspirant
Ok, everything almost OK.
Got 2 x 2 GB DDR2 memory, installed fine, works fine.
Got Noctua NF-R8 CPU fan, installed fine (a tight fit), works fine.
Got Noctua NF-S12A FLX fan for the SYS fan, installed fine, but doesn't rotate as fast as I think it should.
So, the ReadyNAS Pro Pioneer I have is up and running and very quiet. Both fans rotate and I can feel the airflow, altough the one fro the SYS fan is quite weak.
Status > Health says the SYS fan is currently doing 1288 RPM and CPU fan 912 RPM.
SYS temp is 72 C / 161 F, which is more than the normal range (65 C / 149 F).
I have calibrated the fan, but there seems to be no change in the RPM, or a very small one. I did install ToggleSwitchProCPUFan_1.0-x86.bin and booted. It said the install and fan speed adjustment was successful, but there is no change.
Any ideas what to do to make the Pro Pioneer make the SYS fan rotate faster?
I plugged the fan connectors to the same plugs the old ones were in.
