apoleon
May 30, 2014Aspirant
Pro Pioneer fan failed (?)
Hello! I have a ReadyNAS Pro Pioneer Edition 6-bay NAS device, about 4.5 years old. Running constantly without any major probems (once, however, I had to move all data off and reformat the system d...
apoleon
Jun 05, 2014Aspirant
fastfwd wrote: Are both fans installed in the correct orientation? Air blows toward the label side of the fan, so the CPU fan should have its label facing IN, and the case fan should have its label facing OUT.
Oh dear. I've never felt this dumb before. Both fans were installed the wrong way. At least I was consistent. Now I feel the warm air coming out the case, and no longer feel the air coming out of the CPU holes (as there is no air coming out). CPU temperature dropped a lot, but SYS temp is still close to the 65 C limit, but anyway within the bounds.
SYS temp was 70 C at 1200 RPM. Now 62 C at 1200 RPM.
CPU temp was 50 C at 900 RPM. Now 30 C at 800 RPM.
Disks are at 36 C, about 8 C lower than before. The ambient temperature is a bit high, 26 C near the NAS box.Note that I replaced one failing disk and resyncing is in progress. I guess that could have an effect on the temperature, too. Thanks again!
