hobbes487
Oct 05, 2015Guide
Pro Pioneer v4.2.27 - FrontView won't save configuration
I have a Pro Pioneer that I have had for just over 5 years without any issues major issues. Occasionally it would freeze up and I would just force it to shut off by holding the power button and it w...
- Oct 05, 2015
Thank you! I was able to use Tech Support mode to clean out all the Crashplan upgrade data. ForntView is now working and I can access my files again. Last remaining issue is that I can't access the ReadyNas via SSH so I can't upgrade the jre to the necessary version. Any pointers to figure out why SSH isn't working?
hobbes487
Oct 05, 2015Guide
Well, it looks like I can no longer log in via SSH. Only FrontView is working, but I can't save anything.
hobbes487
Oct 05, 2015Guide
... and yes I am running Crashplan on it.
- StephenBOct 05, 2015Guru - Experienced User
Then this thread explained what happened: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/985781#U985781
If you can't log in with ssh, maybe you can manage tech support mode?
- hobbes487Oct 05, 2015Guide
I inalled the SSH community addon again and now I am back in to SSH. I tried your command for installing the latest jre, but it did not work. Do you have the command to do that?
