wdolson
Feb 16, 2016Guide
Problem Adding 3rd Disk in ReadyNAS 214 #26473764
I have a ReadyNAS 214 running 6.4.2 that is about 10 days old. I started with 2 6TB drives (WD Red on the compatability list) and I've been busy backing up systems in my home office and started to run out of space already. So I got two more of the same drives.
When I started the system the first time, it paired the two drives into RAID 1 automatically, which was good. The drive display said "RAID (RAID 1) under the image of the chasis. The X-RAID button has the green bar on the right. It doesn't say X-RAID-2 anywhere, but all the documentaiton for OS 6 refers to X-RAID-2 so I assume it's that.
According to NetGear's documentation, if you have X-RAID enabled, you should be able to just pop a drive in and it will add it to the volume, in this case increasing the formatted capacity from 5.5 TB to 11 TB. However, that didn't happen. The 3rd drive is dark and the tool tip says "Disk State: UNKNOWN". The drive is brand new and I shut down the system, checked the drive in Disk Manager in Windows and it is in fact a clean drive, no partition. I rebooted the system with the new drive in with no change.
I've looked at a number of people who had problems installing new drives, but I'm none of their problems appear to apply here.
Did the X-Raid go and paint me into a corner with RAID 1 and now I'm going to have to start over to get all these disks to work together correctly? I hope not. A lot of the data is duplicated since it was just moved from other drives, but this is going to be a major mess to make sure all the data is backed up. I don't want to do that for 4 TB of data!
XRAID should have expanded to RAID-5 when you inserted the new disk. You should still be entitled to phone support, so I suggest contacting Netgear at support.netgear.com.
It would take a while to expand btw, and performance will be significantly reduced while that is happening.
- wdolsonGuide
I wish they would tell you in the instructions what to expect as far as notices when the new drive is inserted. There was a warning about it taking a while, but it took a while for the Raid-1 pair to get set too. I think it was about 18 hours. However, there is no notice of anything and there was no degredation of performance. As far as the operation of the system went, it was like they 3rd drive wasn't there.
I e-mailed for support but got back an ambiguous message that both seemed to indicate that my problem wasn't covered by support, but also asked for more information. I sent the requested information, but so far no response. At least your response is the first actual confirmation something isn't working right.
You have 90 phone support for a new purchase, so I would try chat or phone instead of email.
The expansion process requires either reading or writing every sector in the data volume, so it slows down as you add more disks.
The expansion is lower priority than normal file access, but the disks are still used heavily, and seek time of course increases, since the heads are moving around a lot more..
