plauterbach
Apr 22, 2013Aspirant
Problem booting ReadyNAS NV after IP address change to DHCP
I have a ReadyNAS NV that has been running fine. However, I today changed from a hard coded IP address on an old subnet, to DHCP. It gave me a warning about not being able to access when the IP change...
mdgm-ntgr
Apr 23, 2013NETGEAR Employee Retired
I agree that is possible that it is hanging on a bad disk. That would probably be more likely than other problems.
Once you have your system back up and running it would be nice to have a look at your boot_info.log as that should confirm if the VPD is fine or not.
