SorenB
Oct 23, 2018Aspirant
Problem changing Admin password
Hi,
Hav problem to change admin password. It worked earlyer but now I cant change it any more. And I can not add a new user.
Any ideés?
Kind regards,
/Sören
SorenB
Oct 24, 2018Aspirant
Hi,
I get a nother tips. Log in with ssh on the unit and enter "passwd" and that worked. Now I have changed the password without doing a OS reinstall.
Regards
/Sören
Oct 24, 2018Guru - Experienced User
It doesn't generally work. I'm thinking that something you did resulted in changing the password to that value.
- SorenBOct 24, 2018Aspirant
Still I can't change password from the web interface. But now how I can change via ssh it's ok for me.
Regards
/Sören
- mdgmOct 25, 2018Virtuoso
Your change may/may not survive a reboot. Things to check would be e.g. root volume usage, shadow file and the management service database.
