cat71
Sep 06, 2017Aspirant
problem changing IP
i used 10.1.2.10 as IP for nic eth0. eth1 has IP 192.168.178.10 now i conect to 192.168.178.10 unter network i want to change ip 10.1.2.10 to 10.1.1.10. ip 10.1.1.10 subnet 255.255.255.0 rou...
cat71
Sep 07, 2017Aspirant
Hello,
Firmware 6.8.0.
I check it from different Computers, with sometimes IE or Chrome (Ubuntu, WIndows 10).
I try direkt connect to a switch with only one line and only one pc on an other port. (only eth0, only eth2, both)
i try eth1 dhcp enabled.(connect to router (dhcpd) , and its possible to change the adress auf eth1).
i change eth1 to the same subnet, and same IP from the the last setting bevore i change the IP of eth0,
nothing helps.
i have no problems to change other setting .
is there a possibility to change the ip in a config file ?
space of nas:
df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 3862208 1192356 2443960 33% /
tmpfs 254200 0 254200 0% /dev/shm
tmpfs 254200 472 253728 1% /run
tmpfs 127104 7492 119612 6% /run/lock
tmpfs 254200 0 254200 0% /sys/fs/cgroup
/dev/md127 8776244352 7556139084 1218066804 87% /data
df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 63109 441 62668 1% /dev
/dev/md0 1048576 43645 1004931 5% /
tmpfs 63550 1 63549 1% /dev/shm
tmpfs 63550 599 62951 1% /run
tmpfs 63550 28 63522 1% /run/lock
tmpfs 63550 9 63541 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
Marty_M
Sep 07, 2017NETGEAR Employee Retired
Hello cat71,
It does appear the OS partition is in a good condition. Changing the ip address from the config file will require backend access to the NAS if you are well versed with linux I believe that will work. I would recommend to perform an OS re-install, part of the process will reset the network setting of the NAS.
Marty_M
NETGEAR Community Team
- cat71Sep 07, 2017Aspirant
im working with linux since 20 Jears, but the is /etc/network/interface emty
cant you write me, where is th config file for network.
Reinstal is no so good, i have a long list of access rights for nfe and smb.
- cat71Sep 09, 2017Aspirant
try the OS reinstall
eth1 was resetet to dhcp.
but eth0 don't reset, its still the 10.1.2.10
- Marty_MSep 10, 2017NETGEAR Employee Retired
Hello cat71,
Upon properly performing OS re-install the NAS NIC card should go back to DHCP. Just to confirm other NIC card went back to DHCP except eth 0 is that correct?
Marty_M
NETGEAR Community Team- cat71Sep 10, 2017Aspirant
yes thats korekt
eth0 static no change
eth1 static (192.168.178.10) -> dhcp (192.1... (ip block i dont, use))
the nas is conected to 2 different subnets, both subnets connected to a router, on the 192. subnet (connect to eth1) no dhcp server configured.
- Marty_MSep 14, 2017NETGEAR Employee Retired
Hello cat71,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
- Marty_MSep 11, 2017NETGEAR Employee Retired
Hello cat71,
There is a possibility we are encountering a software or hardware problem. For isolation we can try to reflash or upgrade the firmware of the NAS to beta version and check if that will make a difference. Do you have a backup of the data save on the NAS? We also have an option to perform a factory reset on the NAS and then reconfigure the it from scratch and transfer back the data to the NAS but we need to make we have a backup of the data.
Marty_M
