KenTanker0us1
Feb 13, 2019Tutor
problem creating a new rsync backup job
Hello friends, not sure what I'm doing wrong here. I'm trying to create another rsync backup job to the front usb port.
I'm matching the process I used on the other jobs I've created but I'm ge...
- Mar 04, 2019
Hopchen wrote:
Very likely the issue is that rsync is not enabled as a protocol, on the USB.
I assumed that both backup jobs were going to the same USB drive - if that's the case the issue is more likely to be on the source share.
But rsync needs to be enabled on both the source share and the destination. So check both.
Mar 04, 2019Guru - Experienced User
KenTanker0us1 wrote:
Host: 127.0.0.7
This should be 127.0.0.1
-But if I set up a new job from a different share:
From remote system
Host: 127.0.0.7
Protocol: remote:Rsync Server
Port: 873
Path:audio-video
Also, make sure that rsync is enabled for the audio-video share.
