Joe-9O
Jan 12, 2021Aspirant
Problem initializing RN214
I have factory reset my ReadyNAS RN214. I was going through the basic set up. At the last stage where I would get to get to the general administration screen, I get error message: Failed to set ad...
Jan 12, 2021Guru - Experienced User
Can you log into https://nas-ip-address/admin using the default admin password (which is password)? Use the real IP address of the NAS of course.
- Joe-9OJan 13, 2021Aspirant
Thank you for the suggestion.
In the interim, I just cancelled the process.
I used Raidar to get to the admin page and managed to login using the new password that seemingly had been rejected.
I was then also able to set up a recovery password.
I am not sure why this issue happened after factory reset but it seems to be ok now.
Thank you
Avinash
