ChrisModica
Aug 06, 2021Aspirant
Problem Setting Quotas on Shares (ReadyNAS 422)
Re: Problem Setting Quotas on Shares (ReadyNAS 422) Hello All, Currently I am trying to set Quotas on Shares on our customer’s NAS. (ReadyNAS 422 / version 6.5.1) The procedure we are usi...
Aug 06, 2021Guru - Experienced User
Try going to the volume settings wheel, and disable quota there. Then re-enable it, and try to set it for the share again.
- ChrisModicaAug 10, 2021Aspirant
Hello Stephan
Thank you for the suggestion. I will try this and let you know if it worked.
Thanks
