datamonkey
Oct 09, 2010Aspirant
Problem with 24-bit FLAC streaming
Okay, I'm using a new PS Audio PWD/Bridge combo device as media player, and though it sees my entire library on my NVX and plays everything just fine, the files are not displaying the bit rate accurat...
datamonkey
Oct 11, 2010Aspirant
sphardy, thanks, I very much appreciate the reply. I'm glad it is not transcoding, but it appears that some servers (Asset uPnP and others) are chopping bitrates down to 16 instead of 24. Not transcoding per se, but reducing bitrate when they stream. I just want to make sure that ReadyDLNA does not do that. Because it appears to be the case right now. Twonky streams clearly show up properly as 24bit, but ReadyDLNA does not. Nor does Asset uPnP. Trying to get to the bottom of this is tricky.
Thanks again.
Thanks again.
