datamonkey
Oct 09, 2010Aspirant
Problem with 24-bit FLAC streaming
Okay, I'm using a new PS Audio PWD/Bridge combo device as media player, and though it sees my entire library on my NVX and plays everything just fine, the files are not displaying the bit rate accurat...
datamonkey
Oct 13, 2010Aspirant
Just to put the wraps on this thread, and for the record in case anyone is trolling. ReadyDLNA is not reducing bitrate at all, it turns out it was a very bizarre bug in the PS Audio digital lens firmware that is causing the bitrate of files to display improperly on the front panel of the PWD/Bridge. The files are actually being played just fine in actual 24bit resolution, just wasn't displaying properly. The PS Audio developers have the fix in for the next release.
Cheers, and thanks again sphardy!
