loddar61
Oct 11, 2011Aspirant
Problem with access via CIFS, NFS works fine
Hello perhaps someone is so kind to help me with a problem which really makes me mad: I've got a ReadyNAS Ultra 2, some weeks ago I resetted the Ultra to factory default while installing 2 2TB HDs. ...
sphardy1
Oct 11, 2011Apprentice
Then it appears I was completely wrong - the path is clearly correct. In which case I would recommend you contact tech support
The admin users configuration is correct - the built-in admin user always has full access to all shares
