bealehere
Mar 30, 2013Follower
Problem with DLNA finding media
Hi,
New to the forum, well posting anyway, normally just browse and find my answer. However not this time, I am a bit stuck.
The dlna scans, and does not display all my media when trying to access it through my media player, this is a samsung tv new series 6.
after checking logs it did keep hitting one file and then not going past that, deleted that but still does not want to scan all my media files, I have it selected to video only as thats all I need.
Please see below the logs from the past month. Please ignore the connection quitting line, that was when I had it on auto power on and off, that is now disabled.
Why are there so many errors?
Thanks
Rich
[2013/03/23 08:05:37] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/23 08:05:37] minidlna.c:907: warn: Creating new database...
[2013/03/23 08:05:37] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/23 08:05:37] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/25 19:12:16] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/25 19:12:21] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/25 19:12:21] minidlna.c:907: warn: Creating new database...
[2013/03/25 19:12:21] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/25 19:12:22] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/25 23:00:31] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/26 17:01:59] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/26 17:01:59] minidlna.c:907: warn: Creating new database...
[2013/03/26 17:01:59] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/26 17:02:00] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/26 23:00:13] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/27 17:02:11] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/27 17:02:12] minidlna.c:907: warn: Creating new database...
[2013/03/27 17:02:12] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/27 17:02:12] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/27 23:00:13] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/28 17:02:04] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/28 17:02:04] minidlna.c:907: warn: Creating new database...
[2013/03/28 17:02:04] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/28 17:02:04] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/28 23:00:21] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 16:35:53] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 16:35:54] minidlna.c:907: warn: Creating new database...
[2013/03/29 16:35:54] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 16:35:54] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 16:53:53] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 16:53:53] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 16:53:53] minidlna.c:907: warn: Creating new database...
[2013/03/29 16:53:54] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 16:53:54] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 16:54:22] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 16:54:28] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 16:54:28] minidlna.c:907: warn: Creating new database...
[2013/03/29 16:54:29] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 16:54:29] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 16:54:36] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 16:54:42] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 16:54:43] minidlna.c:907: warn: Creating new database...
[2013/03/29 16:54:43] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 16:54:44] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 19:04:33] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 19:04:33] minissdp.c:775: error: sendto(udp_shutdown=10): Invalid argument
[2013/03/29 19:04:33] minidlna.c:1254: error: Failed to broadcast good-bye notifications
[2013/03/29 19:05:04] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 19:05:04] minidlna.c:907: warn: Creating new database...
[2013/03/29 19:05:05] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 19:05:05] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 19:05:17] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/29 19:05:20] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/29 19:05:20] minidlna.c:907: warn: Creating new database...
[2013/03/29 19:05:21] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/29 19:05:21] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/29 23:00:13] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/30 07:21:41] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2013/03/30 07:21:41] minidlna.c:907: warn: Creating new database...
[2013/03/30 07:21:42] scanner.c:731: warn: Scanning /c/media/Videos/Films
[2013/03/30 07:21:42] minidlna.c:990: warn: HTTP listening on port 8200
[2013/03/30 07:49:17] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/30 07:49:18] minidlna.c:153: warn: received signal 15, good-bye
[2013/03/30 07:49:23] minidlna.c:1069: warn: Starting ReadyDLNA version 1.1.0-rc4.
[2013/03/30 07:49:23] sql.c:88: error: prepare failed: no such column: VALUE
SELECT VALUE from SETTINGS where KEY = 'UPDATE_ID'
[2013/03/30 07:49:23] minidlna.c:384: warn: Creating new database at /var/cache/minidlna/files.db
[2013/03/30 07:49:25] scanner.c:690: warn: Scanning /c/media/Videos/Films
[2013/03/30 07:49:25] minidlna.c:1107: warn: HTTP listening on port 8200
[2013/03/30 07:49:26] metadata.c:742: warn: Opening /c/media/Videos/Films/._Django Unchained (HD).mkv failed! [-122]
[2013/03/30 07:49:26] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Django Unchained (HD).mkv!
[2013/03/30 07:49:32] metadata.c:742: warn: Opening /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv failed! [-122]
[2013/03/30 07:49:32] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E18.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E18.HDTV.XviD-NoTV.avi!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E19.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E19.HDTV.XviD-NoTV.avi!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E20.HDTV.XviD-2HD.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E20.HDTV.XviD-2HD.avi!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E21.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E21.HDTV.XviD-LOL.avi!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E22.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E22.HDTV.XviD-NoTV.avi!
[2013/03/30 07:52:28] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E23.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:52:28] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E23.HDTV.XviD-NoTV.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E17.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E17.HDTV.XviD-LOL.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E18.HDTV.XviD-2HD.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E18.HDTV.XviD-2HD.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E19.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E19.HDTV.XviD-LOL.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E20.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E20.HDTV.XviD-LOL.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E21.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E21.HDTV.XviD-LOL.avi!
[2013/03/30 07:52:36] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E22.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:52:36] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E22.HDTV.XviD-LOL.avi!
[2013/03/30 07:53:50] minidlna.c:154: warn: received signal 15, good-bye
[2013/03/30 07:54:05] minidlna.c:1069: warn: Starting ReadyDLNA version 1.1.0-rc4.
[2013/03/30 07:54:05] minidlna.c:384: warn: Creating new database at /var/cache/minidlna/files.db
[2013/03/30 07:54:06] minidlna.c:1107: warn: HTTP listening on port 8200
[2013/03/30 07:54:06] scanner.c:690: warn: Scanning /c/media/Videos/Films
[2013/03/30 07:54:07] metadata.c:742: warn: Opening /c/media/Videos/Films/._Django Unchained (HD).mkv failed! [-122]
[2013/03/30 07:54:07] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Django Unchained (HD).mkv!
[2013/03/30 07:54:07] metadata.c:742: warn: Opening /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv failed! [-122]
[2013/03/30 07:54:07] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv!
[2013/03/30 07:54:13] minidlna.c:154: warn: received signal 15, good-bye
[2013/03/30 07:54:20] minidlna.c:1069: warn: Starting ReadyDLNA version 1.1.0-rc4.
[2013/03/30 07:54:20] minidlna.c:384: warn: Creating new database at /var/cache/minidlna/files.db
[2013/03/30 07:54:27] scanner.c:690: warn: Scanning /c/media/Videos/Films
[2013/03/30 07:54:27] minidlna.c:1107: warn: HTTP listening on port 8200
[2013/03/30 07:54:27] metadata.c:742: warn: Opening /c/media/Videos/Films/._Django Unchained (HD).mkv failed! [-122]
[2013/03/30 07:54:27] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Django Unchained (HD).mkv!
[2013/03/30 07:54:30] metadata.c:742: warn: Opening /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv failed! [-122]
[2013/03/30 07:54:30] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/._Zero Dark Thirty (HD).mkv!
[2013/03/30 07:55:12] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E18.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:55:12] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E18.HDTV.XviD-NoTV.avi!
[2013/03/30 07:55:12] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E19.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:55:12] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E19.HDTV.XviD-NoTV.avi!
[2013/03/30 07:55:13] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E20.HDTV.XviD-2HD.avi failed! [-122]
[2013/03/30 07:55:13] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E20.HDTV.XviD-2HD.avi!
[2013/03/30 07:55:13] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E21.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:13] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E21.HDTV.XviD-LOL.avi!
[2013/03/30 07:55:13] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E22.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:55:13] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E22.HDTV.XviD-NoTV.avi!
[2013/03/30 07:55:13] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E23.HDTV.XviD-NoTV.avi failed! [-122]
[2013/03/30 07:55:13] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 4/._Brothers.and.Sisters.S04E23.HDTV.XviD-NoTV.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E17.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E17.HDTV.XviD-LOL.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E18.HDTV.XviD-2HD.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E18.HDTV.XviD-2HD.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E19.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E19.HDTV.XviD-LOL.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E20.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E20.HDTV.XviD-LOL.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E21.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E21.HDTV.XviD-LOL.avi!
[2013/03/30 07:55:29] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E22.HDTV.XviD-LOL.avi failed! [-122]
[2013/03/30 07:55:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Brothers and Sisters/Season 5/._Brothers.and.Sisters.S05E22.HDTV.XviD-LOL.avi!
[2013/03/30 07:56:52] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Greys Anatomy/Season 9/._Episode 11.mkv failed! [-122]
[2013/03/30 07:56:52] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Greys Anatomy/Season 9/._Episode 11.mkv!
[2013/03/30 07:58:16] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Sons Of Anarchy/Season 2/._Episode 11 - Service.avi failed! [-122]
[2013/03/30 07:58:16] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Sons Of Anarchy/Season 2/._Episode 11 - Service.avi!
[2013/03/30 07:58:16] metadata.c:742: warn: Opening /c/media/Videos/Films/01 TV Series/Sons Of Anarchy/Season 2/._Episode 12 - TheCulling.avi failed! [-122]
[2013/03/30 07:58:16] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/01 TV Series/Sons Of Anarchy/Season 2/._Episode 12 - TheCulling.avi!
[2013/03/30 08:06:59] metadata.c:742: warn: Opening /c/media/Videos/Films/Godfather I & II/._The Godfather Part 2 1974.mp4 failed! [-122]
[2013/03/30 08:42:55] metadata.c:742: warn: Opening /c/media/Videos/Films/The Fast and the Furious - Collection/._Fast and the Furious 5 (HD).mkv failed! [-122]
[2013/03/30 08:42:56] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/The Fast and the Furious - Collection/._Fast and the Furious 5 (HD).mkv!
[2013/03/30 18:49:39] minidlna.c:1069: warn: Starting ReadyDLNA version 1.1.0-rc4.
[2013/03/30 18:49:39] minidlna.c:384: warn: Creating new database at /var/cache/minidlna/files.db
[2013/03/30 18:49:40] minidlna.c:1107: warn: HTTP listening on port 8200
[2013/03/30 18:49:41] scanner.c:690: warn: Scanning /c/media/Videos/Films
[2013/03/30 18:52:12] metadata.c:742: warn: Opening /c/media/Videos/Films/A-M/Godfather I & II/._The Godfather Part 2 1974.mp4 failed! [-122]
[2013/03/30 18:57:29] metadata.c:742: warn: Opening /c/media/Videos/Films/N-Z/The Fast and the Furious - Collection/._Fast and the Furious 5 (HD).mkv failed! [-122]
[2013/03/30 18:57:29] scanner.c:488: warn: Unsuccessful getting details for /c/media/Videos/Films/N-Z/The Fast and the Furious - Collection/._Fast and the Furious 5 (HD).mkv!
Thanks
Rich
1 Reply
- dcard2000AspirantI am having a similar problem where ReadyNAS is having problem getting the metadata information from the video files. I have only tried the .TiVo files, and over 90% of TiVo files cannot get details. I have a ReadyNAS Duo v2.
