struan99's avatar
Sep 05, 2021
Can Orbi cause problems for Virgin Media SuperHub 3?
Problem: I am using a Virgin Media Superhub 3 in modem mode, connected to a Netgear Orbi RBR50 router. Periodically (sometimes every 5 minutes or so, sometimes once an hour), the Superhub loses its internet connection, its lights flash, and it restarts -- a process that takes a few minutes. When that happens, I lose all internet connectivity, both over ethernet and wifi (we lose our phone line too, which is wired to the Superhub). This problem has persisted for a week. Prior to that, my setup gave me fast, stable connectivity for some months. Does this make sense to anyone?
More info: I had assumed the problem was with Virgin Media, but Virgin Media hasn't been able to fix my issue (though they haven't yet tried replacing the Superhub). I'm now wondering if it could be the Orbi? When I put the Superhub into router mode, and disconnect the Orbi, the router seems to work OK.
Until recently, my Orbi router was wired to a Netgear network switch (managed), model GS116E. I had ethernet cables running from the network switch to 3 Orbi satellites around our home. A few other devices were connected to the switch via ethernt, and various others were connected over wifi. In order to diagnose the problem, I switched off the Orbi satellites and disconnected everything from the router (meaning the Superhub is wired to the Orbi RBR50, and nothing else is wired to that). But I only get a few minutes of connectivity over wifi before the Superhub resets itself. Any suggestions would be gratefully received :)
Thanks,
Struan
  • I wasn't able to open that spreadsheet (I don't have Excel, and tried in Google Spreadsheets without success). Also, the Superhub 3 lost its connection again this morning while running in router mode and connected to the Orbi. However, I had another (a third!) visit from Virgin Media today. The engineer switched my hub, giving me a Superhub 4 to replace the Superhub 3. When the engineer tried to put that Superhub 4 in modem mode, with the Orbi connected, nothing worked. When he tried putting it in router mode, and disabling wifi via the Superhub 4's control panel, everything did work. I've had a stable connection for the intervening 3 hours or so. I'll cross my fingers that it all continues working, though I'm still baffled as to what went wrong originally, or *why* this approach would work. Thanks for helping me with all this!
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute them back ON.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Is the RBR directly connected to the ISP superhub router or is there a switch in between. Normally, any external router should be directly connected to the modem/ont. Any switches needed are connected behind the RBR or external router.
    Try option #2 then #3:
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • struan99's avatar
      struan99
      Tutor
      Thanks for the reply, but some of this answer doesn't seem relevant to the issue I described. Is my issue familiar? I'm just a bit unclear why I've had good stability for months, then it would drop a week ago; are you sure DMZ mode is the answer here?
      • struan99's avatar
        struan99
        Tutor
        Just to answer one question: my Orbi's firmware is V2.7.3.22. I don't think home square footage is relevant to my issue. Thanks!
  • CrimpOn's avatar
    CrimpOn
    In addition to leaning on Virgin Media to explain why their Superhub keeps restarting itself, how about trying this experiment:
    Leave the Superhub in router mode and reconnect the Orbi.  There are two choices for the Orbi:
    • Leave it in router mode.  Thousands of customers do this every day. They unbox their new WiFi (of any brand) connect it to the existing ISP box, use the WiFi credentials printed on the label, and never look back.  This works fine unless the customer relies on some very specific applications, such as port forwarding, VPN into the Orbi LAN from the internet, and certain types of internet gaming.
      This way, anything you had the Orbi set to do (besides those specific items) remains in place, such as assiging IP's to devices, defining custom DNS servers, using Armor or Circle, etc.
    • Change the Orbi to access point (AP) mode. This allows those applications to be hosted on the Superhub (not the Orbi because it is no longer a router).
    This experiment will be a step toward ruling out the Orbi as the "problem."
