h_tsopelas
Sep 15, 2015Aspirant
Problem with FTP
Hello, when i open my ReadyNas 102 today i see that the FTP was disabled. I try to enable it, but even if i press aply to system settings it is still disabled? Why? I did not do anything! Yesterday i...
- Sep 16, 2015
It is ok now! I make Reinstall os from this page http://kb.netgear.com/app/answers/detail/a_id/22892/session/L2F2LzEvdGltZS8xNDQyNDI0NDQ1L3NpZC9kVWt3RER3bQ%3D%3D
Sep 15, 2015Guru - Experienced User
h_tsopelas wrote:
If i make "Perform Factory Default" i will loose all my data of the disks?
Yes. You will also need to completely reconfigure the NAS and reinstall any apps.
h_tsopelas
i send also the ftp log of today if that helps :)
2015-09-15 00:00:12,135 serverilias proftpd[14740] 192.168.2.2: ProFTPD killed (signal 15)
2015-09-15 00:00:12,197 mod_ban/0.6.2[14740]: detached shmid 425984 for BanTable '/ftp_ban.tbl'
2015-09-15 00:00:12,197 mod_ban/0.6.2[14740]: removed shmid 425984 for BanTable '/ftp_ban.tbl'
2015-09-15 00:00:12,203 serverilias proftpd[14740] 192.168.2.2: ProFTPD 1.3.5 standalone mode SHUTDOWN
2015-09-15 08:00:25,882 mod_ban/0.6.2[1094]: obtained shmid 0 for BanTable '/ftp_ban.tbl'
2015-09-15 08:00:26,029 serverilias proftpd[1225] 192.168.2.2: ProFTPD 1.3.5 (stable) (built Wed Sep 17 2014 10:25:54 PDT) standalone mode STARTUP
2015-09-15 08:01:20,707 serverilias proftpd[1225] 192.168.2.2: ProFTPD killed (signal 15)
2015-09-15 08:01:20,709 mod_ban/0.6.2[1225]: detached shmid 0 for BanTable '/ftp_ban.tbl'
2015-09-15 08:01:20,709 mod_ban/0.6.2[1225]: removed shmid 0 for BanTable '/ftp_ban.tbl'
2015-09-15 08:01:20,712 serverilias proftpd[1225] 192.168.2.2: ProFTPD 1.3.5 standalone mode SHUTDOWN
- h_tsopelasSep 16, 2015Aspirant
- h_tsopelasSep 17, 2015Aspirant
Today when i open the nas it has the same problem! I can not do reinstall os every day! Why it does that? I do not understand!
- StephenBSep 17, 2015Guru - Experienced User
Do you still have the 90 day support after purchase?
Yes i have
h_tsopelas wrote:
Yes i have
Then I suggest opening a support case. FTP shouldn't disable itself that way.
