_Phil_'s avatar
_Phil_
FTP Folder Names Problem
I can connect to the FTP just fine on my ReadyNAS 204 but the folders are shown with long names full of Unix information.
For example a folder that should show up as just "FTP" instead shows up as... (owner id and name replaced)
"users;UNIX.mode=0770;UNIX.owner=xxxxx;UNIX.ownername=xxx; FTP"
If I try to enter the folder I get the following in the logs...
Status:    Retrieving directory listing of "/users;UNIX.mode=0770;UNIX.owner=xxxxx;UNIX.ownername=xxx; FTP"...
Command:    CWD users;UNIX.mode=0770;UNIX.owner=xxxxx;UNIX.ownername=xxx; FTP
Response:    550 users;UNIX.mode=0770;UNIX.owner=xxxxx;UNIX.ownername=xxx; FTP: No such file or directory
Error:    Failed to retrieve directory listing
It's trying to access with the full wrong folder name. If I manually try to enter with the correct name "FTP" it works fine.
I have the same issue on any client.
  • OK, well there's at least two "solutions", and thanks to all for the help.
    1. Use a client that used LIST instead of MLSD, e.g. CoreFTP.
    2. Change the FTP user primary group in AD to have no space in it. This could be a new group, which is what I did instead of renaming "Domain Users".
    Cheers.
  • StephenB's avatar
    What firmware are you running?
    I'm running 6.9.1 on my RN526x, and I am not seeing this behavior with FileZilla or with Chrome.
    • _Phil_'s avatar
      _Phil_
      Yep I'm also running 6.9.1.
      Also just tried this on my old ReadyNAS 104 and it has the same issue.
  • I'm having the exact same issue.  CoreFTP works just fine.  Netgear refuses to accept that their update did something.
    • Sandshark's avatar
      Sandshark
      Sensei
      Sounds like it's unique to the ARM based systems.  Has anyone with an Intel based system seen this?
    • _Phil_'s avatar
      _Phil_
      You have saved me, CoreFTP works for me too! That is such good news for me, thankyou for letting me know. I think you're right, one of the updates broke this as it used to work fine. I wonder what it is about CoreFTP that means it reads it correctly? Thanks again!
      • tnorton00's avatar
        tnorton00
        Guide
        You're welcome, Windows FTP browsing works fine as well FYI.
ProSupport for Business
