_Phil_
Dec 05, 2017Aspirant
FTP Folder Names Problem
I can connect to the FTP just fine on my ReadyNAS 204 but the folders are shown with long names full of Unix information. For example a folder that should show up as just "FTP" instead shows up as.....
- Jan 16, 2018
OK, well there's at least two "solutions", and thanks to all for the help.
1. Use a client that used LIST instead of MLSD, e.g. CoreFTP.
2. Change the FTP user primary group in AD to have no space in it. This could be a new group, which is what I did instead of renaming "Domain Users".
Cheers.
Marc_V
Jan 16, 2018NETGEAR Employee Retired
Hi _Phil_
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards
_Phil_
Jan 16, 2018Aspirant
Cheers.
