_Phil_
Dec 05, 2017Aspirant
FTP Folder Names Problem
I can connect to the FTP just fine on my ReadyNAS 204 but the folders are shown with long names full of Unix information. For example a folder that should show up as just "FTP" instead shows up as.....
- Jan 16, 2018
OK, well there's at least two "solutions", and thanks to all for the help.
1. Use a client that used LIST instead of MLSD, e.g. CoreFTP.
2. Change the FTP user primary group in AD to have no space in it. This could be a new group, which is what I did instead of renaming "Domain Users".
Cheers.
Dec 06, 2017Guru - Experienced User
What firmware are you running?
I'm running 6.9.1 on my RN526x, and I am not seeing this behavior with FileZilla or with Chrome.
_Phil_
Dec 10, 2017Aspirant
Yep I'm also running 6.9.1.
Also just tried this on my old ReadyNAS 104 and it has the same issue.
- StephenBDec 11, 2017Guru - Experienced User
What FTP client are you using?
- _Phil_Dec 11, 2017Aspirant
FileZilla and WinSCP both have the same issue.
I just tried with web browser and it works... but I can't upload with the browser.
So it's very weird, thick client doesn't work, browsers show it properly...
It is weird, and I'm not seeing it myself with FileZilla. I didn't try WinSCP though.
